F20 narrow tread
James Williams
Tractors been stuck for some time,Its been soaking for about a mounth.Hit down on pistons with a piece of oak and it broke loose.After hitting back and forth the motor cranks over easely.Now pull the pistons and sleeves and then reinstall
PB Blaster,Ive had good luck with it.I cut a 2x2 piece of oak,and I had made a post driver out of a 2 1/2 in piece of iron pipe with a heavy steel cap welded to it.slipped the driver over the oak and hit down on the pistons.This works better than using a hammer.I cut the oak 30 inches long,this way there was no chance hitting the head bolts.Ive probally broke 30 motors loose like this.
