Farmall 504 steering wheel seal
fordtrk
Hi guys new to the site. I have a 504 that I got a seal kit for and it doesn't fit. Been searching all over to find out what I need. I pulled the steering wheel and there was a snap ring then a seal. # C/R 374527 R91 . The kit had 3 parts spacer, seal, dust cover. The spacer and seal are smaller in diameter. This seems to have a seal 1st after the snap ring and no dust cover. Finished off the seal getting it out. The turning the wheel to build pressure trick and push things out didn't work. Any help would be greatly appreciated. Thanks Frank
(quoted from post at 16:49:21 09/03/20) You have to have the engine running to get the oil to work for you on the bushing getting out.
Yes tried. This seems to be different. The seal was a tight fit fluid would leak out but not move anything after removing the snap ring. The kit that steiner sent me is wrong. Everything is smaller in outside diameter. I got the seal out with a pick. I think I finally found a seal to replace it but waiting for it to come in. The kit they sent has a dust cover a spacer and the seal. Mine seams to just have the seal.
