Crazy Horse
First off, I'm assuming that the coolant drain plug(s) for the model A and B are in the same location. I have an early Farmall A with the non-pressure radiator. So here's my questions .....
- Are there two drains, one for the block and one for the radiator?
- My radiator does not have a drain in the bottom rad pan. Maybe the rad drain is in the lower rad hose? If so, not there in my tractor.
- If there is a block drain location, I sure can't find one. Where would I look? On the right side of the block I see a plug but I suspect it is a blank off for a drilled oil passage.
This little video shows the guy draining the radiator (and maybe the block at the same time). I cannot figure out where he is draining from ....
Untitled URL Link
Untitled URL Link
