#1 I checked hyd fluid levels and it show a bit over full on the dip stick like maybe an inch above the full mark.
#2 none of the indicator lights work so using that to help trouble shoot is out.
#3 fired it up and tried the steering and it did not want to turn and trying to was hard and the steering wheel was jerky. Pull both the hyd remote control levers and tried the steering again and it did steer both left and right for a bit then get hard and jerky again.
#4 tried the brakes and both pretty much go to the floor but have not opened them up to inspect the disk condition as of yet
There is not even a wire to the for lack of better term the probe on the MVC. So I wonder if I could hook my test light to the probe tab and the battery and use it to indicate things. Both the operator and I-T that came with it are lacking a whole lot of info
