So as long as I had oil pan off I dropped oil pump and am replacing the oil pump spring and thought there was supposed to be a spring and ball but instead I have a spring that fits inside this plunger. So its a International 340 utility with a 135 cubic inch gas motor. Is this the correct parts for this pump and does this replace the ball and spring style ? did international ever use the old spring and ball style or did they allways have this style? if I new that it had this plunger style I would have saved myself the 8 dollars and just put some small washers in it and stiffened up the spring for more pressure. thanks
