Hello,
John Carter, new member here. I'm the proud owner of my grandfathers 706 gasser. Recently, while putting around, I suddenly saw what I though was smoke emitting from around the throttle. It was actually a fine mist of hydraulic fluid, I looked down hydraulic oil was puddling around my feet. I shut down, then started briefly to try to identify where it was leaking from. There was oil pouring down one of the steel hydraulic lines leading to the orbital pump.
I figured that one of the steel lines had rusted through. Pulled the lines and pressure test with compressed air at home and cannot find any leak.
Now, I'm scratching my head. If the lines are intact, which they appear to be, what should I investigate next?
Thank you very much for any ideas.
John
John
