B Project Pic
Red Raider
04-25-2001 11:23:15
Slogging along with the steering gear assembly and wire brushing of the rims and wheels, bolt heads, fan, and miscellaneous parts. One of the most useful tools I need to buy next is a bearing press . The hold ups have been the problem of separating the right brake pedal from the shaft, finding a salvaged starting switch that mounts to the starter, and starter push rod with gas tank support bracket. Since the B had no electrics, I've needed quite a few items, including a battery box. A loomed wiring harness sounds great, and the vinyl decals are terrific, but more $ ($140!).
third party image
Paul Shuler with pic
04-26-2001 20:10:22
 Re: B Project Pic in reply to Red Raider, 04-25-2001 11:23:15
third party image
Hey RR, this is the 41 B that my son and I picked up for $250 this fall. I have had to do a lot of work on the front bolster and steering. It has not run in over 12 years but is free. Your photo inspires me to get to work on it. I am working on a Super C right now and it is eating all my cash. Looks great, keep up the good work and keep us updated
gene b
04-26-2001 20:06:52
what I like a man with a plan you need a 1725 belt for the gen get a good ground at the steering post and the system will work get a good ground at the reg also might want to run 12ga for the lites there is some voltage drop with 14 JC WHITNEY has some fiberglass tubing that works real well looks good when painting is finished you can make a harness for about 10 bucks looks very good when finished got to have a gnd thru the box on the steering post it will work
gene b
04-26-2001 06:53:00
better find a fan assy that has two pulleys to run your generator make sure you get a gen and reg that are matched if you need parts info will be glad to help
Red Raider
04-26-2001 11:23:41
 Re: Re: B Project Pic in reply to gene b, 04-26-2001 06:53:00
Yep, I've got a new (oiless) fan assembly that was going on the SC until I decided to restore the B first. Should the gen and reg be matched by amperage? Both are 6v.
Ralph
04-25-2001 16:26:25
Red Raider: Hey, I like it. The first tractor I started driving was a near new 1941 B. I can remember that first test drive like it was last week rather than a long long time ago.. Do it up good. Enjoy it. Thanks. R
The Red
04-25-2001 11:28:05
RR your garage is WAY too clean! :)
Red Raider
04-25-2001 19:03:19
 Re: Re: B Project Pic in reply to The Red, 04-25-2001 11:28:05
At least I haven't spilled over a 5 gallon drum of old oil and grease/water sludge. I was 'cleaning up' with a leaf blower a while back and blew out about a cup of the stuff by mistake, shoulda covered it with the lid. Leaf blowers are great.
big fred
04-25-2001 12:38:26
I agree, Red, if it was me, I woulda kicked that bucket of oil over by now.
The Red
04-25-2001 12:49:29
 Re: Re: Re: B Project Pic in reply to big fred, 04-25-2001 12:38:26
He definitely is NOT a Tales candidate. :)
