Greetings,
I have a farmall 560 D with a farmhand F11 loader with bale grapple. I primarily use it for moving bales and loader work. The TA is not working correctly and the clutches do not release correctly and if I stop the tractor under load the transmission bind and I can,t get it out of gear. I have learned to shift to neutral while still moving. I have a slot with a mechanic to repair.
My question is should I repair the TA or install a TA delete assuming one is available for a 560?
