Order Farmall Cub Parts Online
Cub won't speed up
Pat
04-25-2001 05:25:31
Ran fine then got worse....started to die under a load...then would die when you sped up. Now won't go past idle without dying.
Changed points, condensor, rotor, cap, and wires. No change. Rebuilt carberator...no change...HELP!
51 cub....
p
04-25-2001 08:15:16
 Re: cub won't speed up in reply to Pat, 04-25-2001 05:25:31
is it a magneto or distributor?
Pat
04-25-2001 10:24:45
 Re: Re: cub won't speed up in reply to p, 04-25-2001 08:15:16
It is a distributor
Bob M
04-25-2001 11:32:42
 Re: Re: Re: cub won't speed up in reply to Pat, 04-25-2001 10:24:45
If you partially close the choke will motor run better - even if just for a few seconds? If so your problem is restricted fuel flow. To remedy proceed as follows:
1 - Remove the fuel line at the carburetor, then open the shutoff at the sediment bowl. You should get a solid stream flowing out the end of the line - not just dripping gas. If you don't, clean the sediment bowl screen and check for an obstruction in the shutoff valve. Also check for junk in the opering where the sediment bowl screws into the tank.
2 - If you see good fuel flow, the problem's an obstruction inside the carburetor - most likely something plugging either the float valve or the high speed metering jet. Disassemble the carburetor again and throroughly clean everything inside. Check and clean the screen (if there is one) behind the fuel inlet nut. Blow out all internal passages with compressed air before reassembly. Check for proper float level and make sure the float is not binding before installing the float bowl.
Good luck!
p
04-25-2001 08:14:59
