1933 F12 Starting Tank
We removed the starting tank today and it was easy! Whoever owned this tractor must have really looked after it. Every nut and bolt undid easily and had shiny and greased threads. Photographs of tank attached.
SadFarmall
Exactly. There was the change to putting the starting tank inside the main tank and then on the F14 tractors it went back over the rocker cover. I think this version is neater than the F14 variant. I'll get it cleaned up and work out its capacity.
SadFarmall
Looks great! If I could trouble you for a
picture if the depth of the tank, and
approximate radius of the bottom. Also,
could you take a set of picture of the hood
and where the neck hols is?
Thank you.
No problem. I was working on it between showers of rain yesterday. I'll get some better pictures and post them here.
SadFarmall
