Company Logo Shop Now
Front wheel attatching bolts
Ralphwd45
08-12-2020 19:05:22
I bought a narrow front pedestal, for my M, and also the two 16" rims (3 loop), used, out of Texas. I sold the WFE that was on it. I need to know what size, and length, and grade, the proper bolts, should be, to mount the 3 bolt rims on the pedestal? Are these bolts fine thread? do they use lock washers?, or are they using lock nuts?, and what grade should they be? There are only 6 of them, to buy, and YT parts did not seem to offer them! I don't have any original bolts to copy!
roy prins
08-14-2020 17:19:44
 Re: Front wheel attatching bolts in reply to Ralphwd45, 08-12-2020 19:05:22
grade 8 fine thread with a lock nut is My choice -- but if the holes in the hub or the rim are wore out they might need tightening once in a while -- If You have a loader on it tighten more often -- ask Me-- I have had one! If You cant find 2-3/4 use 3 inch and put the wheels on the inside like they were supposed to be--- that seems to put less pressure on the bolts -- good luck ! Roy
300guy
08-13-2020 15:58:08
I just replaced the ones on my 300 a year ago. The bolts I used were 5/8 x 2.75 National fine, Grade 8 with a lock washer. Mine was a narrow front just like an M or H.
haas
08-13-2020 11:39:32
Others gave you the size. Use at least a grade 5 bolt. If mine, I would use grade 8.
DeltaSteve
08-13-2020 08:09:41
5/8 x3". Square was 'factory',but common hexhead work just fine.The hex is hidden in the middle so no one sees that they are not'factory',but most people dont know the difference anyway.
D Slater
08-13-2020 03:55:46
Wheel cast number ending with a DA suffix or lower used 5/8 x 2.5 bolt. DB suffix used 5/8 X 3. Early coarse thread and then fine thread. 13 gauge washer and a lock washer was used by IH. Whatever works to stay tight gets the job done.
highwayman
08-13-2020 02:45:30
Nothing special about them. Originals were fine thread but it’s rare to find them on one. They’re 5/8 by about 3”
Ralphwd45
08-13-2020 12:59:37
 Re: Front wheel attatching bolts in reply to highwayman, 08-13-2020 02:45:30
Thanks guys! I will try a 2.5 and see if I need the 3" or not. Then I think I will buy grade 8 ,fine thread, with nuts and lock washers, for the final mounting. With no front end loader, I could get by, with grade 5, but might as well go with grade 8. I am not trying to be original, but do want a good job, for future users, safety.
Copyright © 1997-2020 Yesterday's Tractor Co.
