Company Logo Shop Now
Bolt problem on a BN
Charlie M
08-12-2020 17:17:16
I'm in the process of changing the transmission oil seal on the right side of my BN and hit a problem with a bolt. Previous owner had put on a 3 pit hitch and welded a spacer to the cross bar that the swinging drawbar attach to and bolted it to the bottom of the axle tube. He used the spacer as the swivel point for the 3 point hitch arms. Problem is I need to disconnect it from the axle tube and one of the bolts is too close to the part used for the 3pt hitch swivel to get anything other than an open end wrench onto.I can't budge it with that type of wrench. The other bolt I could get a socket onto and it took a piece of pipe on a breaker bar to move it so the bolts are tight. Is there anything other than a torch that might work on this thing. I can't think of anything but thought I would ask first before I do something I'm sure to regret. It was pretty clever the way the hitch and hydraulics were added to the tractor but it makes working on the tractor a real pain as all the add on parts are in the way of doing anything. If I had a drawbar I would cut the spacers off but I haven't seen a drawbar for a BN for sale yet.
Tom Massachusetts
08-16-2020 11:36:22
 Re: Bolt problem on a BN in reply to Charlie M, 08-12-2020 17:17:16
Weld a 3/4 nut to the 15/16 head and you will have room for a wrench or socket
Russ from MN
08-15-2020 09:38:27
When you get the existing bolt out you could replace it with an Allen head bolt, they you wouldn't have this problem again.
gene bender
08-14-2020 06:08:51
Just use one from a B CUT 8IN and weld
Ken Hansen
08-13-2020 09:14:57
I was also thinking of something along that line of attack.
This is one of the reasons see a picture would be very helpful!
brooktre
08-13-2020 06:30:05
Might be able to tack weld a sacrificial 15/16 open end.
Ken Hansen
08-13-2020 05:20:12
Agree like the old saying "A picture is worth a thousand words"
Sometimes trying to fix what someone else cobbled up can be a major challenge! Without seeing it very hard to make suggestions.
Might have to get a bit aggressive and resort to cutting head off with a cut off wheel in a 4.5 inch grinder or maybe fighting in there with a hack saw. Just try to put any damage on the parts you might be scrapping and not on the castings of the tractor.
Janicholson
08-12-2020 18:11:28
Tubing wrenches might work, they are tougher than a crow's foot. Jim
Charlie M
08-13-2020 02:53:42
 Re: Bolt problem on a BN in reply to Janicholson, 08-12-2020 18:11:28
Jim - thanks for the info - glad I asked. I've never heard of this wrench before but it might work. I will see if I can get one - its a 15/16 head.
John M
08-13-2020 05:43:50
 Re: Bolt problem on a BN in reply to Charlie M, 08-13-2020 02:53:42
If all you can get on it is a open end wrench, you wont get a line wrench on it. They slip on like and boxed end wrench. If you can do that, then you dont need a line wrench.
rustred
08-12-2020 20:54:17
i had to look and see what you meant. i have never heard them called that, always know them as line wrenches. as for use on brake and gas lines .
Phil Tibbetts
08-13-2020 02:13:36
 Re: Bolt problem on a BN in reply to rustred, 08-12-2020 20:54:17
Also called Flare nut wrenches in this area. They get a lot better grip on a bolt head, especially if they are 6 point.
Andrew Anderson
08-12-2020 17:30:44
sounds like maybe a crowsfoot socket would help you.
brooktre
08-12-2020 17:29:07
A picture would help with ideas. Also what size bolt is it?
Copyright © 1997-2020 Yesterday's Tractor Co.
