Crookedwrench
Weak battery that is in the marginal range on load testing. Showed 6.2v after overnight charge. Started the tractor OK, loaded the tractor for 30 minutes mowing damp grass with a Woods belly mower. Checked the battery at fast idle with my HF volt meter. 5.9 ~6.1volts.
Replaced voltage regulator last week. Polarized the generator and it was showing 6.8v at fast idle and 7.3v when load tested. I have a heavy duty battery disconnect on my negative cable going to the starter on the positive grounded tractor.
My question is this==== When I use the disconnect when I leave the tractor and then return weeks later and turn the disconnect back on do I need to repolarize the generator? Is it possible that I have damaged the voltage regulator?
I plan to replace battery in the morning, repolarize the gen, and do away with the disconnect and hopefully get a good 6.5~7.1 voltage at fast idle.
Sorry for the long post. I look forward to your advice. Don
