ChampagneNBeer
Hi all,
Got the PTO back today, neighbor welded the linkage plate back on and looks good.
After looking at the PTO, decided to replace the shaft seal as well - already have the gaskets, linkage sesl etc and figured might as well do it and be done with it - the seal looked pretty bad anyway.
Anywho, so to the question.
The part # is 45702D
Looks like accoding to CNH, the new part # is 358812R91
So, question is, I see the 45708D is only .3 inches wide (so would I need 2 or 3 of this seal?
Seems 3 would be perfect as .312 (x3) = .936, and the old seal is 1" wide, but YT says to use 2.
2nd question, is 358812R91 the same width as 45708D? Cannot find the width when searching online, only seem to show the inner and outer diameters.
So to recap:
Can someone tell me the width of 358812R91?
And depending on ordering 45708D or 358812R91 - would I use 2 or 3 as replacment?
Here is a pic of the old seal - are these captive or do they remove from this sleeve?
So to recap:
