Hi everyone,
I am in the process of replacing the clutch and seals in the transmission on my Farmall M. I have already split the tractor behind the belly pump and replaced the seals on the front of the transmission. My question is when I remove the bellhousing casting that covers the clutch will the plate that holds the rear of the tractor remain fixed or do I need to support the back of the engine?
Thanks
Tom
Thanks
Tom
