Farmall & IHC Tractors Discussion Forum |
Cant get tractor to crank over
Author |
[Modern View] |
Jeff101637
08-09-2020 09:24:41
bought my first tractor a couple of weeks ago replaced the starter and checked the flywheel to see if its moves it took some doing and then moved till a certain point (probably when it hit compression) so installed starter but it just wint crank any help would be greatly appreciated
Jeff101637
08-09-2020 16:10:52
Re: Cant get tractor to crank over in reply to Jeff101637, 08-09-2020 09:24:41
thanks guys the oil trick worked no to make sure i have spark and then clean the fuel system and then (fingers crossed) she will start right up again thanks for the tips sure i will have many more questions before im done😅
Jeff101637
08-09-2020 11:39:35
forgot to mention earlier that i pulled the spark plugs and still have a hard time moving the flywheel
David G
08-09-2020 13:06:53
Re: Cant get tractor to crank over in reply to Jeff101637, 08-09-2020 11:39:35
It should not be loose, but you should be able to rotate the flywheel at least one revolution one pry at a time with plugs out. If it comes up against something solid, then you have an internal issue. Please try that and post back. I would do this with the clutch in first time.
Jeff101637
08-09-2020 11:37:56
not positive of the tractor info but the plate says model 3444 international. But when i looked for a starter everyone showed a different starter than what was in there?
Jeff101637
08-09-2020 11:35:55
it was not running the previos owner said it ran a year ago
Jeff101637
08-09-2020 11:34:56
take the cover off of what sorry if its a stupid question but unsure what you mean?
David G
08-09-2020 09:48:31
could also have liquid in the cylinders, if a gasser then pull the plugs, squirt in a little oil and crank as suggested.
rustred
08-09-2020 09:38:47
need tractor info, make and how long was it sitting. can have rust in cyl's.
FastFarmall
08-09-2020 09:31:34
Take the cover off, the bottom and then turn it back, with a big screw driver or what ever you can get some leverage with, take the plugs out if it's a gas, squirt some motor oil in there too,maybe two shots with a pump can! Was it a running tractor when u bought it?
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
1935 John Deere BN History - The History of My Tractor - by Alexander G. Knox. My grandfather, Orval A. Knox of Chandler, Arizona, affectionately known as Pa, purchased this tractor new from the John Deere/Caterpillar dealer (now Arizona Machinery) in 1935. It was his first new tractor and his first with rubber tires. He used it on his farm growing cotton, alfalfa, corn, wheat, milo, barley, and oats. My father, Norman L. Knox, recalls Pa putting a mower on the tractor during the day and then
... [Read Article]
Latest Ad:
11-2-34 tires
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
