Company Logo Shop Now
Water pump leaking grease
DanMD
08-09-2020 05:39:37
I have a recently rebuilt water pump on a SMD. After about 20 hours of use, I found some black grease slung out from the groove at the pulley. I spoke to the rebuilder and he said not to worry as the front seal is installed backwards to allow grease to burp if necessary. I have cleaned this up several times and it continues to sling some grease. The book states it will happen if over greased. I haven't greased it since the rebuild. I removed the grease zerks and the cavity isn't full of grease or coolant. All looks well from what I can see, just wondering why this keeps slinging grease. Im assuming it is just pushing out excess grease from the original bearing packing of grease, but thought it would have stopped by now.
Janicholson
08-10-2020 15:43:54
 Re: Water pump leaking grease in reply to DanMD, 08-09-2020 05:39:37
The lube manual is clear that there is little grease needed in there. like 2 pumps a year. (look it up as I do not have the manual in hand) but you probably just need to let it stabilize then clean it once. Jim
DanMD
08-09-2020 10:42:11
I'm guessing the rear oil seal failed and it is getting past the felt washer.
DanMD
08-09-2020 10:40:20
DanMD
08-09-2020 10:34:57
It is leaking past the generator pulley groove where it is in line with #7 on the print.
D Slater
08-09-2020 10:14:47
Strange, have installed aftermarket seals in the hub with no problem. Didn't install backwards though. Can you tell if it has a gasket behind the piece the fan bolts to?
DanMD
08-09-2020 10:01:52
This makes sense to me. But I have cleaned it up good 6 times or more and it keeps coming out. I removed the grease zerk and it is red grease in there, but there is plenty of air space as in the cavity isn't packed full. The grease coming out is black in color, feels and smells like normal grease. I'd say I get an equivelant of half a pump of grease out if I run it for an hour. I took the belt off and the bearings feel good. No coolant leaking anywhere that I can detect.
David G
08-09-2020 14:13:19
 Re: Water pump leaking grease in reply to DanMD, 08-09-2020 10:01:52
The you do have seal problem, personally I would not install the seals backward as it would always push out grease when it gets warm.
David G
08-09-2020 09:52:11
My suspect is over greasing, clean it up and see if it happens again. It is important to remember that grease is not compressible so some must leave if some added.
rustred
08-09-2020 09:36:47
it is possible that when rebuilt it has been greased more than necessary and now with coolant heat the grease is flying out. my thinking.
FastFarmall
08-09-2020 06:00:55
That is interesting.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
Latest Ad: JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
