Wanted Int. 340 C135 motor parts
marlin54
Im looking for some engine parts for my 340 utility that has a C 135 ci gas motor. Bought it not running with head off and so lost were the 2 outside studs for the rocker shaft and 2 head bolts with washers and 2 pushrods that measure 10 3/4" . also I have a broken oil ring on a piston so a set of rings off a good used piston would help.
International used the C 135 in the following : most 340's from 59 to 63 and , 330 row crops from 57 and 58 , 404 row crop from 61-68 and 2404 industrials .
The 135 is a small block engine that is used on many many IH tractors such a A, B, C Supers, 100's, 200's. You want to look and see if these parts match.
(quoted from post at 19:16:21 08/08/20) I believe the A, B, And C used the 113 engine.
Russ you are correct. I was not clear in what I stated. The 135 is a small block engine. These other tractors used the small block engine such as the 113. A lot of the parts are probably the same. So you could check these engines to see if they used the same parts. There were a few differences in the 135 but I can't remember what they are. Any way you want to check the parts to make sure they match.
The 135 block is different from the 113 because that engine is a 3 1/4 bore and where the sleeve o-ring goes
the bore in the block is larger to fit the larger sleeves you can not use those sleeves in the 113 block because
of the 3 1/4 sleeve being larger. The 113 block will take the 3 1/8 bore sleeves. The newer blocks were used in
later SA and SC TRACTORS. You can bore the 113 block to take the larger sleeves where the o-ring goes
