ChampagneNBeer
Hi All,
Rustred inspired me to check out the pistons on my M based on the compression numbers I was seeing (in the 130s, cold without wot, all within a few % of each other).
Turns out I do have stepped pistons - which is kinda cool.
Anywho, upon peeking into the cylinders, I noticed cylinder 2 was dry - like bone dry, while the other 3 were wet.
What could cause this and what should I check?
Or not worry about it?
I am doing valve adjustment as soon as can and have most everything pulled apart, so guess now is the time to do it.
Thanks!
Thanks!
