Absent Minded Farmer
- Location
- Gehl Country, Wis.
I wanted a cheap original oil gauge for my H. Found one on eBay a while back that is for a T-4. I thought it should work, the run the same engine. Figured out, after a while, that IH skimped out & put a C123 in those little crawlers. Is there really that much of a difference in oil pressure between the C123 & the C152? My H pins the needle almost right away cold. Might the gauge be bad & that's why it was pulled? Should the gauge be ok, is there a restrictor that can be used? Something like what would be used on a hydraulic line to choke down the pressure.
Just wondering. If all else fails, I'll have to hit up eBay again for another good used takeoff.
Thanks,
Mike
Thanks,
Mike
