I’m looking at a friends 384 that the PTO lever does not work. It moves freely like it’s not connected but I can feel the shaft turning while moving lever when tractor is running. I’ve looked at a service book which tells me there is an arm on the end of the shaft that engages PTO.
Do I need to pull the transmission cover or do I remove the lever/shaft thru the side of transmission? I see three bolts hold a small cover with the shaft.
