This message is a reply to an archived post by Brian Luton on June 06, 2016 at 17:46:27.
The original subject was "Farmall Super A Ignition Switch".
I just experienced the same problem with my Super A. Replaced condenser, coil. Points open and close but no spark from coil.Voltmeter doesn't move when plunger pulled out but the starter turns over.Ordered new points and a switch. If you see this Brian, did the new switch work? Are there grounds that could be involved? Not sure where the grounds are.Can't see any problems with wires.
Thank You
Thank You
