ChampagneNBeer
Hi All,
Worked out the details on the old model M and have decided to convert to a 12v system.
Questions:
I know many say the Delco 10SI alternators are an option, but is hood modification needed? If yes, how so? Any bracket tips?
Seems a 10si would be a pretty tight fit so here are some other options, would like to know your thoughts...
What about a 40 amp kubota 3 wire alternator?
https://www.discountstarterandalternator.com/p/new-alternator-kubota-thermo-king-12v-40-amp/
It is smaller, still internally regulated, and has internal fan?
OR
What about a chevy mini 40 or 50 amp alternator?
https://powerparts360.com/chevy-mini-alternator-denso-street-rod-race-3-wire/?gclid=EAIaIQobChMI88y4yY356gIVz8DACh3ZRA3mEAQYAyABEgKv7PD_BwE&gclsrc=aw.ds
Again smaller than a 10si, also internally regulated and internal fan?
Aside from brackets, and the other obvious parts I will change (coil, resistor, wiring etc) any little tricks/tips or common mistakes to watch out for?
Questions:
OR
