This is my first post on here. My father
and I collect and restore farmall tractors
as a hobby. We have had a stage 1 super H
for years. Its an early one. The early
stage 1 models had small standard H style
carbs ours in serial #8108. It came from
Indiana. We are in Va. An older friend that
worked at an IH dealership told us that
when they first came out the tractor had
the higher gearing and with the smaller
carb couldnt keep up, so they switched it
to a M style carb.a local guy called us the
other day to see if we were interested in
his old farmall. We ended up buying it. Its
a stage 1 super H with the larger carb. We
got it home and cleaned it up and to our
astonishment it serial# 8109. Its complete
random luck we ended up with 8108 and 8109
and the crazy part is they are the
transition from the early style small carb
to the later large carb. Does anyone have a
Super H around those serial numbers to help
confirm this? They both were in great shape
with low hours and have correct year
castings on the blocks so i highly doubt
the carbs were changed. Just trying to do
some extra research.
