Company Logo Shop Now
384 PTO problem
Dacaseguy
07-16-2020 20:26:59
Any one have any idea why the PTO on a 384 won’t work. It has not worked for a while, that’s all I know. Any thoughts would be appreciated. Thanks
jimb2
07-17-2020 06:16:40
 Re: 384 PTO problem in reply to Dacaseguy, 07-16-2020 20:26:59
Hi, look at 354 PTO link below.
The 354 has same PTO as your 384, look at the post from damojordan with the parts photo with the PTO engagement lever, Item #4 has a roll pin that engages into Item #5 collar that connects the rear PTO shaft to the front PTO shaft that is driven by the PTO clutch. If the roll pin on Item #4 gets sheared off then you cannot engage the PTO. The roll pin can be replaced by remove the 3 bolts on Item #3 and pulling the PTO engage lever out. It takes some luck and feel to get the PTO engagement lever and pin re-installed in the collar.
jimb2
07-16-2020 21:55:02
More explanation of don’t work would be a great help to diagnose the problem.
Most common problem is shearing the roll pin on the PTO engagement lever, so when you put the PTO lever in gear it is not pushing the collar that connects the rear PTO shaft to the PTO drive shaft from the PTO clutch.
Today's Featured Article - Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong. ... [Read Article]
Latest Ad: Scraper 16 yard carry type. Southwest welding manufacturer company, Alhambra California Made around 1938. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
