jjamna
I am in need of a clutch pack for a 460 Farmall PTO. I understand that several different tractors use the same PTO Parts. What all tractors PTO will interchange with a 460? I think the clutch pack is what I need. The spider has 3 fingers. Where the fingers connect to the release sleeve is broken. The picture is what I need.
If you want used do a web search and call around to tractor salvage yards around you, they can tell you what will fit. Right off I would guess a unit out of a 560 would also work. It is possible that the broken parts are still available from IH. I don’t know what you need by your description. Here is a link to the parts page, if it doesn’t go direct to the diagram choose section 116, and click the picture icon at the bottom of the page. That is linked to the new CaseIH parts page it views worse then the old site did on a iPhone. Today must be the cut over day because I can’t get a old version to open. Probably have to get an App on my phone for it.
460 PTO
Was on a website today that said the release sleeve and spider also fits 340,560 2606 and 606. I am just repeating what i read. Also I found one and it is on the way. Thanks.
