W4 Steering Gear Oil?
I can see the fill for this under the steering wheel, but is there a drain plug anywhere? And what goes back in - 80/90 wt gear oil, or something lighter? Manual no help with this.
Thanks,
Tim
The side cover on steering box has to removed to drain the oil and refill with 80W90. For your oil bath in post below there should be holes in the inner ring. When filled to the oil level marked on outside of the cup, the oil will self-level in both rings.
