Tpbrettin2
New User
I recently bought a farmall a with woods belly mower. The man said the water pump was bad on, I did question him if it was truly an A. I found several unique features that many of you have helped to explain. The serial tag doesn't meantion farmall but does say international first box says A second box says FAA third box 162418, 1540 rpm. It does appear to be a water pump leaking out the end shaft, it has the squared axle with the bell housing support. But it also has the hydraulic pump blanked off with a plate. So I ask do I have a A, AI, SUPER A, SUPER AI or just a pile of poop? What documentation do I want?
