504D loss of power
Rftlts
hello. while cutting hay tractor lost power gradually. I found a broken zip tie that appeared to hold these two levers on the pump together. so I wired them together to get off the field. what is the proper installation of the linkage on the pump? Am I missing something? looks like it to me.
Thanks
Loren
There's a lever spring that connects the two levers together, it's probably broken. Spring allows more lever travel when inner lever stop screws contact housing when fully forward or rearward.
