Farmall666 gas governor
PGarrett1
New User
I am having a problem getting the engine rpm set on this motor . I f I get idle speed set correctly it will not run fast enough at fast idle and vice versa . I have used procedure in the I&T manual without success. Any suggestions? the governor arm that moves the rod to the throttle shaft doesn't appear to be traveling far enough in either direction .
There is likely slop in the linkage. Here is a diagram, the solution may be in worn pivot "L"s or holes. It could also be a worn Ujoint that
limits travel. Jim
Linkage.
