The pto on my cub pops out of gear, My question is in following my service manual to disassemble the shaft I should remove the pto shaft and then the shifter rod. Do I remove the rod from the inside and if so how do I keep the pto clutch from sliding off the shaft?I suspect the shifter rod is worn to the extent that it does not hold the clutch in position to keep the pto shaft and the tractor drive shaft connected.I suspect there is a simple trick to this job. Will some one with more experience clue me in? I really appreciate tyhe advice I get from this forum!
Re: cub loboy pto in reply to cheif, 07-03-2020 17:41:57
Ok, you have to take off the gear shifter, aka the top of the trans. Then you take off the pto boss. Reverse it to put it back together. You need the. Top off so that you can align and so that you can change out the gear shifter easier.
Re: cub loboy pto in reply to John M, 07-04-2020 06:17:47
My service and parts manual for this 58 loboy both refer to the part in question as a clutch.My question is how do I remove the lever that moves the clutch to connect the tractor drive shaft to the pto shaft. Any advice welcome!
Today's Featured Article - Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong.
... [Read Article]
Latest Ad:
Scraper 16 yard carry type. Southwest welding manufacturer company, Alhambra California Made around 1938.
[More Ads]
