lee little
The right spindle and steering knuckle on my 806 had a lot of slop so I am in the process of replacing them. The bushings in the housing had some play so I am replacing them. I put them in the deep freeze overnight to hopefully get them in easier. The top one finally went in with quite a bit of effort. With me laying on the ground the bottom one seems to be a harder install. Do I need to remove the housing from the tractor or do one you of you guys have a method that will make this simpler ? Thanks for any help you fellas always amaze with your knowledge' Thanks Lee
