Farmall & IHC Tractors Discussion Forum |
F 20 Sediment Bowl Assembly
Author |
[Modern View] |
Cmore
06-29-2020 07:11:47
Does anyone know an F 20 sediment bowl is the same as an H or M? Mine is so plugged up it won’t drain at all. I’m going to take it off the tank and try to clean out tank then reinstall a new sediment bowl....I’d like to find one with an extended intake (longer), to stick up higher in tank.
rusticredacres
07-02-2020 06:02:13
Re: F 20 Sediment Bowl Assembly in reply to Cmore, 06-29-2020 07:11:47
F20 fuel strainer is 1/4 inch pipe. H and M are 3/8 inch pipe.
DR. EVIL
06-30-2020 04:39:16
I bought a replacement sediment bowl assembly, the WHOLE thing from my C/IH dealer, saw the "Made in China" sticker when I got home, took it back, replacement said "Made in China" too,so damned mad I let it sit on the bench for two years. Gas fumes from the sediment bowl dripping was so bad I half expected to blow the roof off the shop when I flipped the light switch, so I drained the tank last winter and installed it. No more drip! I never could get the old valve apart to repair it like Farmall Gray showed in RPM a year ago.
moonlite37
06-30-2020 04:38:40
Your old one after proper cleaning may be better than a new one
F-Dean
06-29-2020 10:42:46
Take the F-20 sediment bowl off and clean it. Then clean your tank. Yours is a common problem when you first use gasohol. It will dissolve anything that is in your fuel tank and lines.
Jal-sd
06-29-2020 10:15:33
A 3/8 inch tall chunk of appropriately sized copper tubing attached (crimped) unto the top of the inlet tube of the sentiment bulb before it's re-installed will solve the problem.
Cmore
06-29-2020 12:26:39
Re: F 20 Sediment Bowl Assembly in reply to Jal-sd, 06-29-2020 10:15:33
Thanks. I just ordered a Fuel Tank Screen from Steiner...... Goes on top of sediment bowl insert inside fuel tank. It should work.
DeltaRed
06-29-2020 07:37:32
3/8 pipe thread on both. However,if your tractor is set up for dual fuel,you need a special one. If you are just running straight gasoline,an M/H will work. However the line threads will be different. If you want it'factory correct',the answer is no. If you justwant it to work,and don't mind some line modification,yes it will do just fine.An extended intake with a fine screen is available from Stieners for about 8 bucks. The sediment bowl assy is also available from them.
[Options]
[Printer Friendly]
[Posting Help]
[Return to Forum]
[Log in to Reply]
Home
| Forums
Today's Featured Article -
Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong.
... [Read Article]
Latest Ad:
Scraper 16 yard carry type. Southwest welding manufacturer company, Alhambra California Made around 1938.
[More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
