Fast Hitch Drawbar
Cmore
Does anyone have the exact dimensions for a Super C Fast Hitch drawbar? I have bought 2 from members on this board and neither fit! One was a bigger for a 400 or such and this one looks like it should fit but doesn’t! I don’t have names of either person anymore and I’m not paying shipping to send them back!
Mostly, how deep are the prongs?
Thanks
Cmore
There are only 2 sizes.The width is the same,only the 'depth' of the prong is different.the C/SC is the smller one.If the smaller one wont fit,then something is bent/sprung/tweaked.....
Then it’s strange that my Plow, disc, planter and blade all fit but the drawbar doesn’t??
And it was sold to me as a Super C drawbar.
I traced one of my Super C points and carried it the door pocket of my truck in case I ran across any two point stuff. Then if you want to use a small point piece of equipment in a bigger hitch you slip a 1/2 inch shim in each side.
Thanks very much! That’s the first time I’ve seen actual dimensions posted anywhere!
Cmore
Maybe you draw bar is sprung? My post hole digger had shims welded under it, I cut the welds and ground off the welds, works fine,the disc I bought(fit a 300) I cut a 1/2 inch off of the bottom off of the points with a cutting torch and a lot of grinding wheels,it fits my Super C fine.
Update...
Took the Super C Fast Hitch Drawbar to the finest Machine Shop in the area for them-to cut down
per Gab’s demensions.
