Company Logo Shop Now
IH W 400 front rims
tmunday
06-15-2020 19:31:42
Does anybody know where I could find a set of front rims for a W 400, I think they were 18 inch. Thanks Todd Munday
mccormicksw4
06-27-2020 17:56:55
 Re: IH W 400 front rims in reply to tmunday, 06-15-2020 19:31:42
International 400s replaced the Super W6 ta but in June of 1955 IH rebadged the production tractors as W400 since they most reassembled the previous W Series. All of them were equipped with 30 inch rears , some had W6 style fenders while others had larger wheatland style fenders with a flat operators deck
I have owned a few of both varieties
there was only a little over 3300 of them made. the center section could have been changed with the serial plate or are you sure it is only 4 digits? this is not my tractor just a sample pic
tmunday
06-29-2020 06:48:43
 Re: IH W 400 front rims in reply to mccormicksw4, 06-27-2020 17:56:55
my w 400 looks just like the picture except it is a diesel I don't know the history of this tractor the ta housing could have been changed.
BarnyardEngineering
06-27-2020 17:36:43
From what you describe it sounds like a W-400 to me.
The TA housing where the serial number is riveted is the same from a Farmall to a Standard. If you park both tractors side by side you will see a LOT of things are the same, in fact.
What I'm trying to say is, someone could have easily swapped in the TA section of a Farmall 400 because the original TA in the W was out.
mccormicksw4
06-16-2020 13:47:19
Quoting Removed, click Modern View to see I have a bunch of those rims as well. one small correction to above post- channel frame SW6 and SW6T/A only for the 18s- not tub frame
where are you located?
tmunday
06-26-2020 16:22:38
 Re: IH W 400 front rims in reply to mccormicksw4, 06-16-2020 13:47:19
Found rims for the W 400 now I have a question about serial numbers. I looked on tractor data it says the W 400 stopped at 3 thousand and something. My tractor has the wheat land fenders has the w 400 decals but the serial number is 10802. Is this a standard 400 or what. It also has 30 inch wheels on the back instead of 34. Thanks Todd Munday
tmunday
06-16-2020 14:21:52
I am located in NC Maiden 28650 I have just purchased a W 400 diesel. I need the front rims, do you the front wheels also The reason I need the rims someone welded a larger rim to the wheels it is hard to explain. If I can find the right rims I could cut and clean the wheels up or if I can buy both wheels and rims I would like to do that. My e-mail is toddandregina@charter.net. If you e-mail me I also can give a phone number. Thanks Todd Munday
rustred
06-16-2020 07:54:31
i have a bunch of those rims. they are all the same from the super w6, w9, 400,450, and 660. yes 18"
Today's Featured Article - Talk of the Town: Miracle Formula for a Stuck Engine - by Edited by Kim Pratt. Another great discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: I have a stuck 4 cylinder engine. Two pistons right at the top, other two down. From underneath everything looks good. Up top looks bad. Thanks in advance." ... [Read Article]
Latest Ad: Single front for Int M, 706 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
