agdodge4x4
Long day of cleaning up the C. I finally have spark on it. However, found lots of water in the pan with nasy chunky oil. Dropped the pan and cleaned everything along with a new oil filter. Still remains to be seem how much of that got pumped up into the top end.
Anyway, I pulled the valve cover and aside from there being a fair bit of flaky rust that appears to be as old as the tractor, I noticed my rockers on a couple of cylinders are not centered over the valve stem. Some are at least half way off. It's been running fine like that for a while, but perhaps I should correct it? How do you correct it? It appears as though there are 'bushings' between the springs on the assembly and those seem to dictate the horizontal placement of the rocker over the valve.
How does one adjust this? Or do you just buy a new assembly?
