Hi,
I need to replace the warped and badly leaking sediment bow assembly on the 560 diesel and was wondering if any of you guys have done something similar? It has been warped forever but now it just started leaking like a sieve. There was a mix of 4 different thick and thin cork gaskets above the glass bowl and no matter what I try now it will not seal up at all. It seems like the quickest way is to just put a ball valve on (not sure of thread size) but it is nice having a water separator since often times there is at least some water in mine. I don't care about stock appearance, I just need something that that works effectively and doesn't leak. Any help will be appreciated.
