560 rear hydraulic lines
I need to swap out this set of hard lines, have needed to for years. Got to checking it over today. How in the world can you access the manifold bolts at the valve under the dash. Is there a trick to this?
Thanks, Chris B.
I did this to my 560 a couple years ago. I was actually able to get a wrench in there and pulled all 3 bolts out without doing anything except removing More than a couple pieces of sheet metal. It takes time and you wont turn the bolts much at a time but it was easier than dismantling everything. Also, I did get them put back on the same way. I might have actually got the front one out from the front but I can’t remember now.
