cowboy badger
New User
I'm doing in frame oHaul. 806d 361 cu in engine. Standard mains standard rod bearings sizes. Standard size came out. When I start to tighten main caps it gets very hard to rotate the crankshaft. Caps are in correct order, and clean and properly seated.
It acts like there is an undersized bearing installed, you tighten and it stops crank from moving. No pistons are installed, just the mains.
What should I check next?
