djsamuraii
You have probably seen my posts. Yes I'm a noob. However I have my H running great now. I have rewired the electrical system. I have the magneto timed properly. I added an alternator. Its charging my battery good. Now on to the issue. I have a propane setup on my beast and my ensign regulator is freezing. So the tractor runs great for a few minutes then the propane freezes the regulator and it starts to stall until it stops completely. I would really like to replace the Regulator with a new one. Also I noticed that my CARB leaks a ton of propane from the chock or bottom of the carb. Does anyone know where I can find a new regulator and carb that will work on My H. Any advice will be worth millions to me... Thanks in advance.
