H will not start, ran a few years ago, replaced points (0.015" gap) and plugs (0.025" gap), cap/rotor/wires all look good cleaned carb. (rebuilt purchased on this website 3 years ago), checked float, needle valve, main jet. No water in the gas, but gas is 2 years old, I mix in 5 gal new gas. I believe that I have it timed correctly, No.1 on the compression stroke, two lines lined up on the front pulley, and rotor pointed to No.1 on the cap.
I checked compression all cylinders are at ~50 psi, therefore my question (can't find what the compression should be in my manuals)
Is 50psi enough compression for an H to run?
This machine used to the best running thing I own and I let it sit a few years.
thank you
Chris - Southern Maine
thank you
