I got this old tractor running after sitting for 30 years. The rear tires are off to do the brakes. It runs very well and the trans is quiet in all gears except 4th. PTO/belt pulley run smooth and quiet.
I have not driven it yet since the tires were rotten.
It makes banging noises rather than gear whine noises I would expect when idling in high gear (tractor is sitting on blocks waiting on new tires).
If I take the top off the trans, will I be able to inspect the gears?
The manual says the gears can be serviced without removing the trans from the tractor or having to disturb the diff or counter shafts. Is that correct?
