Need Clutch Help!
Just replaced the clutch assembly in my Super A with YT kit #375493KSP. But the clutch isn't working. Push clutch pedal all the way down and the tranny grinds when trying to shift. If I force the shifter the tractor moves off with the clutch pedal still pushed down. I've adjusted the push rod nuts all the way back so as to get the most throw out bearing movement but still no go. I'm at a loss as to where to go next. Besides the kit I also had to replace the throw out bearing carrier as the old one was graphite and broken and cracked. TIA Job
