Company Logo Shop Now
IH300 u brakes
ActionYobbo
05-07-2020 20:12:39
I need to fix the brakes on my good old 300 utility.I have searched and looked but I cant find what brake parts I need to buy.
I need the part number for the fiber disk and how many per side do I need to get. what other parts should I get?
Thanks
ih560
05-09-2020 08:37:45
 Re: IH300 u brakes in reply to ActionYobbo, 05-07-2020 20:12:39
Just make sure to measure everything like Jim recommended, if not, you may get into a situation where you have a lock-up condition with minimal or no braking before the lockup. On my 300u one side had .040" after new discs and the other side had .070" due to wear in the actuators and cover etc. I took off .040" to get it down to the .030" dimension. The brakes work really well now (for what they are), but when I first bought it the brakes were non-existent, and sometimes it would just lockup if you pressed it hard enough trying to stop.
used red mn
05-08-2020 23:33:54
Here is a link to the IH part page. If you click ...Back to the Manual... you can select other sections to view the parts break downs of your entire tractor. Surprised Jim didn’t post it for you, probably to busy laying out all the specs.
Janicholson
05-09-2020 09:58:31
 Re: IH300 u brakes in reply to used red mn, 05-08-2020 23:33:54
Grading final exams. My semester was nasty. I had to change total formats from lab experiences to Youtube and videos. they then had to be doing modules on weld types, lathe operations, computer aided design projects turned into sketching and written exams delivered on a "educational" distance learning platform. I have been sitting too much. Jim
Janicholson
05-08-2020 08:23:21
Clean the ball tracks in the expanders. MAke sure the weird springs holding the expanders together are good. Set the housing on the workbench open side up (on a couple of supports so it is stable, then place all the components into the housing in the order they need to be when on the tractor. Now put a straight edge across the opening and measure down to the top friction disc. The best is about 1/32" or .030" it should not be more than about .050" or it will not work as well as you need, or as long as you want. The pull links that turn the expander halves in opposite directions are at a bad angle when the clearance is too great. The wear on the pinion cage at the tractor, on the expander, and the housing all contribute to this additional clearance. to get the clearance under control, it is necessary to have the mating surface of the housing machined to reduce the clearance. Jim
Charlie M
05-08-2020 02:57:46
Good time to change the oil seals if there has been any leakage. Each side has 2 springs and they can break. Some people just put on new ones no matter what they find.
ih560
05-07-2020 20:18:44
2 discs per side and you can buy them right here on this site.
ActionYobbo
05-09-2020 08:21:20
 Re: IH300 u brakes in reply to ih560, 05-07-2020 20:18:44
I ordered the parts from this site. I got 2 springs 2 discs and 8 balls.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
Latest Ad: JENSEN miniature pump jack. 13W. Operating smoothly. 5 weights. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
