12 volt conversion for Super A, Also IMPLEMENTS NEEDED
Keith
04-20-2001 16:26:10
Hi I was wondering if any one made a conversion kit from 6 to 12 volt for a super A or if any one could tell me if this is done fairly easy.Also is their any one with IMPLEMENTS for sale at a fair price for this tractor I am looking for a cultivator, snow blade, disc, plow and possibly a harrow I live in eastern Idaho and Implements for this tractor are very hard to find. Any Information would be very helpful. Thanks
Tom
04-24-2001 09:04:10
 Re: 12 volt conversion for Super A, Also IMPLEMENTS NEEDED in reply to Keith, 04-20-2001 16:26:10
Try this website: >Link
If>Link they don't appear to have a conversion kit for your tractor, give them a call. I bought one for my H and it bolted right on and works fine!
RON/PA
04-21-2001 15:45:57
THE CONVERSION FROM 6 TO 12 VOLT ON MY SUPER A WAS ONE OF THE SIMPLEST THINGS THAT I EVER DID, SINCE YOU ARE DEALIN WITH A MAGNETO, YOU DO NOT HAVE TO WORRY ABOUT THE VOLTAGE TO THE COIL, SO AS LONG AS YOU ARE ONLY DEALING WITH THE CHARGING SYSTEM, YOU CAN DO JOB IN A SHORT DAY AND HAVE ENOUGH TIME FOR A COLD ONE BEFORE THE SUN GOES DOWN. IF YOU DON'T GET THE INFO THAT YOU NEED, E-MAIL ME AND I WILL TRY TO SEND YOU THE DIAGRAM THAT I USED. LOL RON
Will
04-21-2001 04:14:01
Keith In response to you looking for implements for your super A,I know there,s a difference in money value between Canada and USA but around here in Ont. those row crop cultivators go for around 1600.00. I beleive a lot of that kind of stuff is getting scarce.I got lots of goodies for my super A,plow ,hillers,cults,side dresser,spud diggers.ect.. You have to watch the fence lines.You,d be surprised whats been abandan and forgotten. GOOD LUCK!!! Will
Will
04-21-2001 03:52:47
Keith,there,s a web site with scetched out diagrams for a 6 to 12 volt conversion.Lot of info here. Link
Bob M
04-20-2001 17:18:25
You planning use a generator or convert to an alternator? If alternator, punch below for "do it yourself" instructions.
Tom Owens
04-20-2001 18:14:30
 Re: Re: 12 volt conversion for Super A, Also IMPLEMENTS NEEDED in reply to Bob M, 04-20-2001 17:18:25
Good article. I converted my A and was able to use the same brackets as the generator. Just turn the lower over 180 degrees and add about 4 or 5 washers to make it stand out enough for the belt to line up and the upper bracket will need about 1/2 inch or so spacer between the bracket and the alternator.
