454 gas international hydraulic problem
Tim Bertrand
New User
Hydraulic oil not getting to oil cooler with pro running or not.
Transmission gets so hot causing gas to vapor lock. Where do you start looking?
Hi, see photo below of 54/74 hydraulic oil flow diagram and link to European Service manuals there is a complete section on hydraulic testing and trouble shooting.
Manual 454
Does this tractor have a set of rear remotes/auxiliary hydraulic outlets ? Maybe you
have the control lever not in neutral, but engaged and it is straining the hydraulics
.Mark .
Thanks for your reply. I did pull the mcv and found missing o-ring.
Not sure if that s the problem but it is a problem to be resolved.
Mark, thanks. I will check that valve out also. Could be a o- ring
Causing that. PTO and lift work, when brush cutting I can put hand on cooler with no temperature change.
