shaft for choke on 1951 M
I am in need of a shaft for the choke butterfly to fit a 1951 M Farmall carburetor. I do not need the butterfly nor the screws. My shaft is broke right through one of the screw holes. The shaft diameter is .248. The length is 3.135 not including the bell crank. Does anybody have one of these that they could sell to me? Thanks in advance. Steve Norwood. Banner Ms.
I think I have one. It was is a Generic rebuild kit. The kind you get at Rural King or Tractor supply. It is right at the length you mentioned. Looks to be same diameter. It was in a Super M kit. If you wont to shoot me an email I will send you a picture. Not to sure how to post a picture here anymore.
here it is
If it's really for a SM carburetor the shaft is different from a M because the lever goes on a different side of carburetor. When the right one is installed the bow or curve in lever will be to front of tractor. SM goes in from engine side and SM from outside. Place called Mcdonalds Carburetor and ignition sells new ones and probably other places. You can find them on line and shows price.
Clarifying what Mr. Slaters fingers meant to type...On a regular M the choke lever and shaft inserts from the outside, on a Super M the opposite, it inserts from the engine side.
I have a 1951 M as well and I had the exact same issue a couple years ago. Rather than getting a new choke shaft I ended up welding it back together. I clamped the two pieces together and threaded in a screw into the hole then welded on both sides of the hole. Putting a screw in the hole ensured that the threads all lined up and didn't distort too much while welding. After I welded them I used a grinder to dress the weld so that the choke plate could go back on there. Surprisingly it worked pretty good and hasn't broke again.
If you have not found one yet you might try this place. They have them in the complete kits but you might contact them and ask if they have one laying around. https://link_disallowed/collections/carburetor-farmall-m-super-h-300-400-etc/M-Carburetor
