BN governor question
Charlie M
Finally got my BN I bought last fall running. When I bought it the guy said sometimes when you start it up it goes straight to high rpms and it did today when I started it. By manually working the rod from the governor to the carb I got it to slow down and it stay working normally while I had it running. I don't see any external linkages binding. I've never worked on any of those governors - what should I be looking for.
Gov. housing is probably full of condensation causing the cross shaft bushings to stick. At least that happened to my Super C years ago.
