Thermostat for Super M
Pawnee
04-19-2001 10:55:02
Would the part number be the same for a Thermostat on a Super M as it is for the H.
Thanks!
jiM
04-19-2001 13:33:09
 Re: Thermostat for Super M in reply to Pawnee , 04-19-2001 10:55:02
While rebuilding my M motor (in progress) I did not see a thermostat. Any thoughts on whats going on.
jiM
Bob M
04-19-2001 18:27:37
 Re: Re: Thermostat for Super M in reply to jiM, 04-19-2001 13:33:09
jiM - Most likely the original thermostat failed and got stuck shut. Someone then removed it to keep the tractor running and never bothered to replace it. Happens quite a bit....
jiM
04-19-2001 18:35:31
 Re: Re: Re: Thermostat for Super M in reply to Bob M, 04-19-2001 18:27:37
so Bob I should replace it right, and with what type for a M. What damage will this cause if any if let as is, just wondering on that.
thanks jiM
Bob M
04-20-2001 04:51:01
 Re: Re: Re: Re: Thermostat for Super M in reply to jiM , 04-19-2001 18:35:31
jiM - I highly recommend installing a thermostat. Otherwise the engine's gonna be running cold all the time. This results in rapid build up of condensation inside the engine, dilutes the oil and shortens engine life. Also a cold engine will burn more gas and just generally doesn't run as good.
If you have an AutoZone nearby, suggest their #800-180 (about $4). Otherwise get one from your IHC dealer - figure on $15 - $20 however.
jiM
04-19-2001 18:35:26
thanks jiM
Bob M
04-19-2001 13:07:29
Yes - they all use the same thermostat! Autozone part no. 800-180 will also fit. It looks different, but works fine and costs only about $3 - much less than the IHC part.
Denny Frisk
04-19-2001 12:46:38
I can't prove it in the parts book But I would say Yes!
