Lo-Boy 154 Drive clutch.
Ohio-H
04-03-2020 09:52:04
Can the drive clutch on my 154 be adjusted and how? i'm starting to get some slippage..
John M
04-03-2020 11:20:16
 Re: Lo-Boy 154 Drive clutch. in reply to Ohio-H, 04-03-2020 09:52:04
On a 154, the adjustment is under the tractor, just follow the clutch pedal. Take off the sheetmetal cover, remove the pin that holds the linkage, and adjust the rod. Youll have to reinstall and check, then do all of that over again until its right, but if its slipping, it worn out most likely. It doesnt have to be split to change it, you can slid the engine forward enough to get the drive shaft out.
Ohio-H
04-03-2020 12:53:35
 Re: Lo-Boy 154 Drive clutch. in reply to John M, 04-03-2020 11:20:16
i put a new pedal return spring on, now it slips going up hill, it engages and dis-engages just fine, would this adjustment help?
John M
04-03-2020 15:00:44
 Re: Lo-Boy 154 Drive clutch. in reply to Ohio-H, 04-03-2020 12:53:35
I would take that center cover off and see if the throwout bearing is touching the fingers on the pressure plate first. If they are not, its time for a new clutch, and replacing the spring was just coincidental.
Janicholson
04-03-2020 10:26:10
Yes. Slippage will start to occur as the driven (friction)disc wears thinner. As this happens the pedal gets closer and closer to the stop (foot off the pedal location). the pedal should have about an inch to 1-1/4" free play. this means the pedal can be moved by hand pressure easily for the first inch or so, then becoming harder to push as the clutch begins to release (stop the tractor). This adjustment is made on the rod where the pedal connects to the inside of the tractor middle casting. If there is good freeplay, and it still slips, the clutch needs to be replaced. That requires splitting the tractor. and replacing several parts: driven disc, pressure plate, throweout bearing, pilot bearing, and looking for other wear on linkage and pivot points. Jim
Ohio-H
04-03-2020 13:47:45
 Re: Lo-Boy 154 Drive clutch. in reply to Janicholson, 04-03-2020 10:26:10
Someting must have been stuck,works fine now?
